Hello,
I just noticed that i have gum recession.
I went to the dentist and he told me that i dont have gum disease,my oral health is great and this happened because of the pressure/movement from the braces.Also he said i have a thin tissue in my lower gums.
He told me that in younger patiens the gum and bone regenarates and grow up and that it is also possible for me.But he wasnt sure!
I am so sad because of this..i do everything i can to keep my teeth/gums clean and look what happened..
Is there anyone with the same issue and what happened?
gum recession
Thin gum tissue -- leading to recession usually required grafting.
I often have this fdone prior to placing braces but in certain circumstances it is done after (or even during)
Developer of:
http://sixmonthbraces.com/
- LongInTheT
gum recession
I think things can be done for this by the ortho, but I guess this would not be done with many teeth. Anyway, my ortho just pulled my right front right tooth down and it brought the gum back down to form a proper arch. She then shaved the tooth off where it was now too long. The gum is still receded, but now looks normal shaped so I'm not worrying about it. I thought this was amazing, but I suppose depended on there being enough gum to pull down.
My dentist has also said that tooth movement is good for bone and gums, and in adults as well as kids. But I think he meant a bit of gum growth (I would need loads to get rid of the recessions).
Try not to worry about your gums - we all stare at our teeth so much we are bound to notice things, but others won't.
All the best, LITT
All the best, LITT
With the tight frenum that most likely needs to be removed (frenectomy) along with the graft. I am sure the doc has told you that but might be good info for the others reading these boards.
Developer of:
Yeah I had that too. It's very depressing. I know mine was started by braces but I think I made mine worse because at the time I was using nicotine gum and it's known to irritate your gums. So I don't know if I made it worse but it was SO sore for a while until I stopped using the gum.
My mom had the same thing but she said hers was from brushing too hard but she also had braces when she was like 40 so I don't know if it was a combination of both or what. But she had to get skin grafted onto hers to.
I just hope I don't have to do that because I hate the idea of being put to sleep for anything. I mean I don't like the way it looks but as long as it doesn't cause me any other problems then I really don't care.
