I posted in the other forum, but think it'd be fun tracking my story as it goes over here. I'm 28, going to be 29 in the spring, and this is my first time with braces. I've been self conscious about my teeth since... junior high school, I suppose. Never got braces as a teen. A combination of factors entered into that whole ordeal, financial and personal.
I will try to paint a word picture of my teeth, as I don't think I'm yet allowed to post pictures (being a n00b) and also I'm not really sure I feel comfortable doing so anyway.
My top teeth... aesthetically, most of them look in line except one tooth. The upper right lateral incisor is pushed back, so there is a gap between my front tooth and the canine. It makes me look like I am missing a tooth from most angles (the tooth is still there, just pushed back out of sight). My top arch is also slightly shifted in favor of that gap, it seems. The teeth seem to be migrating to close that gap, so everything is slightly off center. Probably. They didn't say this, but it's kind of my hot take on how things have developed over the years.
The bottom teeth, the canines are rotated a bit and the 4 up front are tilted in weird ways. Looks kind of like a poorly maintained graveyard. They are also kind of wedge shaped.
There are probably a lot of other things going on which went a bit over my head when discussing it.
In spite of all of this, my treatment plan does not require surgery or extractions
I'm looking at 18 months in braces (time of course depending on how my teeth cooperate, I know).
Just got braces on on Thursday 11 Jan. They had a heck of a time getting separators in, too. Evening time I took ibuprofen, as I had a wicked headache as part of the pain. I've not really taken any pain medication since, as it's been manageable otherwise. Needed to use some wax on my bottom lip. Had a really hard time flossing, but I've discovered the magic of cutting the glide floss shorter, which has helped me manage the task a lot more easily. (IMAGINE THAT. SCISSORS! Who knew?) Figured it out after trying the normal threader plastic needly thing + floss and realizing it was only easier because I'd cut the floss a little bit shorter.
I've also been using the waterpik, and a sonicare toothbrush.
Invested in some interdental brushes as well. Never used them before, not sure if I'll be able to get them between my teeth (they are a bit jammed up for sure) but I figured I'd give it a go.
I'll update this as I go. My next appointment is at the end of February, actually. Looking forward to that!
