Swollen gums !!
Swollen gums !!
So I've been having swollen gums for about3weeks now. Yes i brush and floss everyday. Ive tried the salt water thing and nothing. How or what do you do to make em go back to normal ? Lol i was told to rinse with hydrogen peroxide
has anyone tried this?? Anything helps i am desperate right now!! Lol
Re: Swollen gums !!
You may want to have your orthodontist take a look to make sure nothing bad is going on, such as infection. However, with an infection of any sort you'd like likely have pain, swollen lymph nodes in the neck, and fever -- but not always. I don't think anyone here can give you an accurate diagnosis based on your description, but play it safe (I am an RN). Best of luck to you!
Re: Swollen gums !!
I've had this issue both times with braces. Gingimed rinse didn't work, salt water rinses didn't work...I use anti-gingivitis mouthwash, it helps a little. My former dentist said my swollen gums were caused by the pressure from the braces, nothing due to poor oral hygiene. My gums only shrink a little, and then I'm stuck with the leftovers. This happened after my first round of braces. I had a laser gingivectomy before, it wasn't bad. I'm trying to explore other options that may work before I get this done again. Any luck??
Re: Swollen gums !!
Thanks! I waa using a mouthwash i think peridontex? That helped a little. Yeah i thought it was cuz of the pressure too but my ortho said i wasn't brushing. Which i know i was lol so he instilled the thought in me that my oral hygiene was bad. Btw what is a laser gingivectomy?sneed1o1 wrote:I've had this issue both times with braces. Gingimed rinse didn't work, salt water rinses didn't work...I use anti-gingivitis mouthwash, it helps a little. My former dentist said my swollen gums were caused by the pressure from the braces, nothing due to poor oral hygiene. My gums only shrink a little, and then I'm stuck with the leftovers. This happened after my first round of braces. I had a laser gingivectomy before, it wasn't bad. I'm trying to explore other options that may work before I get this done again. Any luck??
Re: Swollen gums !!
Right! I hate when they say that!Jeska0113 wrote:Thanks! I waa using a mouthwash i think peridontex? That helped a little. Yeah i thought it was cuz of the pressure too but my ortho said i wasn't brushing. Which i know i was lol so he instilled the thought in me that my oral hygiene was bad. Btw what is a laser gingivectomy?sneed1o1 wrote:I've had this issue both times with braces. Gingimed rinse didn't work, salt water rinses didn't work...I use anti-gingivitis mouthwash, it helps a little. My former dentist said my swollen gums were caused by the pressure from the braces, nothing due to poor oral hygiene. My gums only shrink a little, and then I'm stuck with the leftovers. This happened after my first round of braces. I had a laser gingivectomy before, it wasn't bad. I'm trying to explore other options that may work before I get this done again. Any luck??
