How Long Does Implant Take?
Just had an implant put in. How long does it typically take to have the bone "grow" around it?
Re: How Long Does Implant Take?
Hey there Christina..
I had to wait 6 months before I could get the crown installed.
I have an appointment to check to see if I am ready at 4 months post implant (in March)
That is longer than I was expecting. But the important thing is that it takes hold well since this is the new "root" of the tooth.
Dear Christina,
We dentists have a big word for the process wherein the bone solidifies around the implant: and that word is "osseo-integration".
Here is my personal experience:
After having a bone graft in the uL4 area the periodontist placed my implant and suggested that I
You can see the course of my implant work at http://drted.com/Implant%20treatment%20 ... %20Ted.htm
Cordially and best wishes for health and happy new year, Dr. Ted
. Since I am a dentist I like to document most things that I do to other people and everything that's done to me.wait for wait three months
Ted Rothstein DDS PhD
Specialist in Cosmetic Orthodontics
and Dentofacial Orthopedics
Adults and Children
Adults and Children
Did you also have some bone implanted or just the screw?
pictures of my teeth
http://www.archwired.com/phpbb2/viewtop ... highlight=
Re: Yes I had both bone graft and implant see documentation
Thank you for inquiring.
I had bone graft and then implant as a prelude to getting my crown soon.
Please go to http://www.drted.com and you will see a section titled "IMPLANTS (EDUCATION)" You will see there links to Parts 1,2,3, and 4 which document all the procedures I have had done including the bone graft and the implant. Cordially, Dr. Ted
Adults and Children
Adults and Children
drted,
Thanks for info and pics. It's been about a month since I had my implant and so far so good.
I have just asked because my oral surgeon did not mention that grafting was necessary. He actually removed all my healthy wisdom teeth too. I was thinking that if he considered doing bone grafting he would have saved some wisdom teeth for that.drted wrote:Thank you for inquiring.
How long after the bone graft did you have the actual implant placed? I'm having a bone graft done where tooth 35 should be as well. My orthodontist told me the implants won't happen until all the teeth are in perfect position and braces are off so that should be roughly 6 months after surgery. Will I need to wait much longer for the implant surgery?drted wrote:Thank you for inquiring.
Upper and Lower Braces Applied: December 4th, 2009
Lefort 1 and BSSO Surgery: February 11th, 2011
