UNLEVEL bottom arch
UNLEVEL bottom arch
Hello brace friends.
My bottom arch is unlevel per the orthodontists. You can see the wire ever so slightly going slanted from one end of bottom tooth to the other end. (front 5 bottom teeth) . One side of the arch looks nice and rounded but the other side looks not as nice. btwn 2 teeth he replaced a wire with a flat looking metal with forks on the end. (>-----< ) is what it looks like.
What causes unlevel arches? How do they get fixed?
I may post some pictures of my lower arch. Seems like the teeth on the bottom seem to be moving slowly, but I know it takes time.
I will post some pictures of my bottom arch. Since I am in braces for 3 months and used to them, not as excited as I used to be, LOL. Time is really moving along now.
My teeth have been slanted since month 3 and I am now on month 31 and they are still slanted. I think it was due to elastics. They were so bad by month 12 or so but it is now a bit better. Ortho says is due to my crossbite that is a "work in progress" very slow in my case. Honestly, I just gave up and I am now convinced it will be another year in braces for me
Hope you guys get it sort it out soon. I am sure that with elastics and some torque, this could be fixed later on in the treatment but always ask your ortho.
I have a similar issue in that my teeth are just not level, period. And, my tops are slanted a bit.. your ortho will have to find out what is causing the slant. It could be a slanted jaw, or it could be just your teeth. In either case, he can fix it but the solution will be different. They can use elastics for example.
My tops are slanted however it's my teeth and I think bracket positioning could have helped but my ortho didn't notice until a long time into my braces (I'm almost 23 months). So, my ortho is going to wait until near the end (hopefully within the next few months) to fix that.
As for my bottoms, my ortho is waiting for the thick wire to level them. I do see progress from a few months ago, but I have to tell you, you're in the beginning stages of your orthodontic treatment so you could have a LONG time before you see complete resolution of this kind of issue. I don't think I'm goign to see my bottoms completely level until the very end.
