Wires are poking me :(
Is there anything I can do to stop them from doing this? I think the insides of my cheeks are getting swollen so they're digging in even more and it's flipping sore! I keep having to pull my cheeks out of the wire...ouucchhh!!
The wax will work anywhere on your braces... a lot of us here use it for the ends until we can see the ortho. The key to making sure it sticks, is to blow air into your mouth, and wait a few seconds, to make sure the wire is "dry" and then put the wax on it. It'll stick better if there isn't too much saliva.
Wax is the key - I also found this mouthwash to be really good at healing ulcers - I used it before I went to bed each night - It lessons the pain and I also found the ulcers cleared quicker...I loved the stuff!
http://www.colgate.com.au/app/Colgate/A ... vacol.cvsp
I just wanted to make sure you know if the wires are the only things poking you. All the hooks on my brackets poke, cut, scratch, and lacerate my cheeks and inside of my lips. I rarely have a problem with the actual wires. Anyway, I wear BraceGard silicone wax all the time. I've had braces for nearly 3 months and I'm still getting sores, cuts, and swollen cheeks. I feel that when I bite down, I have to pull my cheeks out of my braces too. Anyway, hope you have luck with the wax. I did have a poking wire once and it really hurt my gums.
I had the same problem with poking wires at first. I found that wax was the best solution. But there can be another one. After I had the wire changed I checked with my tongue if there's any poking wire and asked my orthodontist to cut again the end of the wire. My first poking wire was quite long (almost 2 mm) and gave me a lot of problems. But this only happened during the first 3 weeks.
29, male
Upper metal brackets - May 12th, 2010
Lower metal brackets - Oct 25th, 2010
You're right, I've noticed some extra pieces of skin on the interior cheek after a while and the wax only protected me during the first couple of weeks until I got used to the brackets. I also used to forget about it and I ate some wax at that time (and I stiil do ).
29, male
