I'm 5 months into my treatment, and it's been good so far, my teeth are straight, I'm onto my finishing wire...
A bit of background - my main issue was overcrowding, with a mild overjet and overbite. I didn't have any extractions, my wisdom teeth are still in place, and I've got metal Damons.
Ok, so here's what I'm concerned about and hoping for some advice. I feel that my lower row of teeth are too protrusive now, as the orthodontist has "raised my bite" so that I don't have so much of an overbite - apparently 1-2mm is ideal? She told me that without the support of my lower row, the upper row may become more retrusive, and my upper lips will not have the support and may flatten. -- Which all makes sense to me.
Well, below I've posted some sihouette photos I created. The 2nd photo has a fuzzy outline, but you can see that the lower lip is clearly protruding beyond the red line. I don't think the brackets contribute much to the protrusion of the lips coz they're really small...
I suppose without extractions, there's no way for the teeth to go but outwards, and this is something I have to compromise on? I suppose it's not worthwhile to sacrifice my premolars for an improved profile, and with the possible risk of flattening of the nasolabial angle?
I'd appreciate any thoughts you guys have on this! Thanks for reading!
