My braces story at 24 yrs old!
aussietrumpeter
Re: My braces story at 24 yrs old!
#31 Post by aussietrumpeter »
Well I haven't updated this in a while so it looks like big changes:
I'm quite happy except that my upper midline is way off.... but my ortho doesn't seem to notice/care and I don't see how it can be easily fixed; on my upper arch I only have a wisdom tooth on one side so I believe the uneven amount of teeth has caused it. Not sure. Otherwise I still have a massive overbite and I'm wearing Class II elastics plus another elastic at night to help close it (which goes between my two front teeth, over the archwire, and is attached at both incisors at the bottom):
tillybrace
#32 Post by tillybrace »
aussietrumpeter wrote:
Tue Mar 27, 2018 11:30 pm
I sometimes feel like you are my teeth twin.
aussietrumpeter
#33 Post by aussietrumpeter »
tillybrace wrote:
Tue Apr 03, 2018 8:59 pm
Haha, yeah it's funny seeing others with the same problems; but you're teeth look great, I hope you get your braces off soon !
jem
#34 Post by jem »
How did your ortho find the space to get all your bottom front teeth in line? Amazing progress!
aussietrumpeter
#35 Post by aussietrumpeter »
jem wrote:
Wed Apr 04, 2018 2:28 am
Good question, because I didn't mention I chose to have one tooth pulled ! I'll post photos.
aussietrumpeter
#36 Post by aussietrumpeter »
The ortho did say I could keep the tooth but it would take "much longer" to get everything to fit.... not sure if that would have worked but we both thought the arch was wide enough without it. And my top arch needs to be a bit larger so no point making the bottom arch too large.
