My braces story at 24 yrs old!
aussietrumpeter
Re: My braces story at 24 yrs old!
#16 Post by aussietrumpeter »
Month 4 progress. Brackets on two front teeth were re-positioned to push them up and make them shorter. The ortho filed down the front teeth a bit and next time will do some more so that they match each other.
istase2000
#17 Post by istase2000 »
Wow the top is straight already! Great progress
aussietrumpeter
#18 Post by aussietrumpeter »
istase2000 wrote:Wow the top is straight already! Great progress
Thanks :) Yours are looking great too !
aussietrumpeter
#19 Post by aussietrumpeter »
Progress pics. Things are moving along...still not enough room for those two blocked out teeth on the bottom. And my top midline is off by a lot so they're trying to fix that now...
jem
#20 Post by jem »
Excellent progress Aussie especially in your top arch. And the teeth that are attached to your archwire at the bottom are also coming into line nicely. Finding space to join those instanding teeth to the archwire looks like a bit of a challenge. Is the metal arch inside your teeth an expansion device? And will you be getting any IPR to help you gain space? Is your upper tongue habit device also an expansion device so that both arches will expand the same?
All those devices must be hard to live with but well worth it for such fantastic progress.
Jem
aussietrumpeter
#21 Post by aussietrumpeter »
jem wrote:Excellent progress Aussie especially in your top arch. And the teeth that are attached to your archwire at the bottom are also coming into line nicely. Finding space to join those instanding teeth to the archwire looks like a bit of a challenge. Is the metal arch inside your teeth an expansion device? And will you be getting any IPR to help you gain space? Is your upper tongue habit device also an expansion device so that both arches will expand the same?
Jem
Thanks Jem. I hope they do some IPR to speed things up and make a little more room but I haven't asked and haven't been told anything.
The arch on the inside bottom I am pretty sure is to keep the molars from rotating. And yes the habit device is also helping to expand the top arch (I actually have gaps now, where before I didn't even have room for all my top teeth).
Can't wait until my teeth look great like yours ! It's definitely worth the trouble.
Josh1794
#22 Post by Josh1794 »
Im new to all this, im 22, also from australia and about to get an expander. Feeling nervous
aussietrumpeter
#23 Post by aussietrumpeter »
It's normal to feel nervous Josh, but definitely worth it.
22at26
#24 Post by 22at26 »
Patience is so hard. I am 3 days in fully braced and I am constantly looking for the changes already haha. I can't wait to see your photos!
aussietrumpeter
#25 Post by aussietrumpeter »
22at26 wrote:Patience is so hard. I am 3 days in fully braced and I am constantly looking for the changes already haha. I can't wait to see your photos!
Hopefully you'll see some changes pretty quickly :)
I haven't updated in a while. Major developments have been:
- Top midline was very off and they have been trying to fix this. It's better but still not perfect.
- One tooth in the bottom arch struggling to fit; I was given the choice to keep it or not but have decided to have it extracted because my bottom arch is wider than my top arch and it will take a lot longer to make space for that tooth. I get it out in a few weeks and I can't wait, it's really annoying me.
- The 'tongue spinner' device I had in my palate broke so I've only got part of it left in
Bottom arch:
Smiling:
Top arch:
noodles
#26 Post by noodles »
Wow, fantastic! Congrats!
atrixa
#27 Post by atrixa »
The progress you've had is amazing!
Upper arch braced (traditional metal) on 17/02/17
Debonded 17/01/18 with a fixed retainer
Estimated treatment time 18 months, actual time 11 months :-*
aussietrumpeter
#28 Post by aussietrumpeter »
Thanks; I'm much happier with my teeth now but more than a year to go... :wink:
erin5550
#29 Post by erin5550 »
Bottom arch:
Smiling:
Top arch:
Amazing progress!
aussietrumpeter
#30 Post by aussietrumpeter »
erin5550 wrote:
Amazing progress!
