I started my journey a couple weeks ago with consultations. I went to three different ortho's. One was a recommendation from a friend and the other two I discovered online.
Consultation #1 told me I was a perfect candidate for Invisalign. He said it would only take 14-16 months for either Invisalign or clear Damon's. I still wasn't sold on Invisalign. There's something about it that doesn't just doesn't feel right to me. He also mentioned I have excessive wear on some teeth and would probably need dental bonding after everything is all said and done.
Consultation #2 seemed to go more in depth than the first one. I found out I have a good back bite. Slight crowding on the top and moderate crowding on the bottom. Top midline is off 1mm and bottom midline right on. Overbite is 20% and overjet is 1mm. He thinks it will take 12-18 months. It may take longer due to the fact that my teeth fit together so well right now. Might take longer to fit everything in properly. He also mentioned we could just bottom braces for 6 months and see where we are, but my bite might change by messing with everything so I would probably need the top done as well. It was also mentioned that we could try Invisalign if I really wanted it and was okay with my teeth being "just okay" at the end. He also mentioned the wear on my teeth but no talk of being excessive or needing dental bonding.
Consultation #3 was the recommendation from a friend. This one said I was not a candidate for Invisalign and my only option was at least one extraction... maybe 4!! He didn't think it would be possible to fit all my teeth perfectly in my mouth. This shocked me to say the least! Especially after the 2 prior appointments where extractions weren't even mentioned or hinted at. This one was also the most expensive. There was also mention of the wear but like #2 no talk of being excessive.
I ended up going with #2. The office was the closest to my work and I felt the most comfortable with them.
Everyone has been really supportive of everything. Some friends have even mentioned that they've thought about getting braces for themselves but haven't gone through with it yet. At times though I doubt my decision and wonder if I really even *need* braces. My teeth aren't that bad. You can't even notice my bottom teeth when I smile... although I tend to wonder if they don't show because I've been conscious of them for so long. But like I've said before, braces are going on tomorrow! I'm hoping that will stop the second guessing!
