I'm somewhat encouraged, because she said she's got 'a few more things to do,' but that we're nearing the end.
I don't know when it's going to be, but am hoping it's going to be within six months.
In the mean time, a gap has formed in between my bottom lateral and central incisors and because I'm only using a partial archwire (because of the swelling on my left side), my bottom teeth started to move from their somewhat straight positions. So she put a powerchain on seven of my bottom teeth. In the week since my appointment, the gap between the incisors has already started to close, which is quite encouraging.
My two central incisors on the top are noticeably out of alignment. She's noticed that one tooth is slightly bigger than the other AND is positioned differently inside the gum than the other. I'm not completely sure what she plans to do with it, but she says in the end it will be straight.
I've noticed that my bite is different; I've had the same elastic configuration for two months now, and my bite comes together more easily; however my overbite and overjet measurments remain the same (3 mm/ 1 mm), and my midline is also remaining the same (1 mm off).
For next time, they are putting a bracket (rather than a band) on that left molar because they need to level it with the other teeth. I hope, hope, hope I see some more noticeable progress soon, because honestly it's hard to come here lately when I see some people having so much progress and I still feel like I'm in the holding pattern.
So for what it's worth, here are some pics. The left ones are from my 26 month anniversary, and the right ones were taken on May 28th.
