Sonicare - 2 minute timer enough?
I have read about your cleaning habits, and mine aren't near as long, but I go through two cycles to clean my teeth...
Ceramic Uppers 9/6/05; metal lowers 11/8/05
4 bicuspids removed 10/26/05
33 y.o. male whose parents couldn't afford braces as a teen---and YES, I TOO AM OBSESSED!!
When I had braces, I think I used it for more than 2 mins, probably 4 was about right. Since my braces were removed, the 2mins is about enough. It beeps 4 times, 1 for each quadrant, and then gives a final beep to let you finish everything off, if you so wish.
It a device which get's better with time though
Wouldn't be without it now.
I lose count how many times my Oral-B slows down and speeds up again.... but on average it takes me 12 minutes or more to brush. That's about 2.5 minutes at least per quadrant, and another 2 on my upper palate bar and tongue ring.
Crappy thing is.... I have to charge my toothbrush after only 3 days of use
Full On Metal! Aug 31, 2005
I'd love to be able to plug in my brush after every use... but my bathroom doesn't have anywhere for me to plug it in. The place I usually charge the toothbrush is the kitchen, but it gets in the way when it's in there.... so I only charge it up overnight (and the next day) when it needs it.
I also have a Crest SpinBrush Pro, and a Colgate Motion for the times I can't use my Oral-B. Sometimes I even prefer the SpinBrush over the Oral-B... but the Oral-B is MUCH quieter and I like using a slower speed.
Does anyone else use a Colgate Motion brush? I've only used it a couple times, and it might go away after a while, but the brush kind of smelled like something was burning while I was using it. It was almost enough to make me gag a couple times. Has anyone else run into that?
Holy Moses!!!
I couldn't imagine spending that much time with my sonicare.
In the evening I use a waterpik, then I floss, then I waterpik again, then I use my sonicare for one two minute cycle (with prescription fluoride toothpaste) and then I am done.
In the morning I use a waterpik, and brush with the sonicare for one cycle using regular toothpaste.
And during the day I try to brush after every meal, first doing a couple rinses with water and then just a quick brush with a regular toothbrush and regular toothpaste, I probably brush for 1-2 minutes.
And my mouth feels peachy!
I really think the waterpik really really helps with the cleaning process, it gets most of the junk out of my braces, and out from between my teeth, so then I am not trying to brush all the food out. By the time I brush in the evening I have already removed almost all the food from my teeth between waterpik-ing and flossing.
It's a two year process.......
I'm told battery 'memory' is a thing of the past these days. I use the Braun Oral-B 'Professional Care - Timer'. The instructions actually suggested you keep the toothbrush on the charging dock whenever it's not in use, stating it would not adversly affect the battery life. So far so good! I probably go through about 3-4 cycles for each brussing session, followed by 10 mins or so of flossing. Sadly waterpik's don't really seem to be available in Australia.
