Which powered toothbrush to get?
It's time for me to break down and buy a powered toothbrush, but the choice is making my head spin.
I'm leaning towards the Sonicare Flexcare Platinum because it has a pressure sensor. The price of it has me gagging a bit though. Add to that, SPAM SPAM SPAM SPAM SPAM SPAM SPAM SPAM' web site totally sucks. It crashes when I try to search for local retailers so I've been manually searching. I've only found one local source so far.
What do you guys recommend? I'd like a sonic toothbrush and I rather not spend more than $150CAN if I can.
Re: Which powered toothbrush to get?
Well, I’m not sure about all the fancy pricy toothbrushes, however, I have an Oral B Cross Action toothbrush. I found it at Walmart for $16. It’s electric and it comes with a base to sit in and charge when plugged in. The tip rotates and the other bristles move back and forth. The replacement heads are about $6 for two. I hope this helps.
Yecats
Yecats
I use an Oral B Triumph - recommended by my dentist. But it is expensive...
I recently saw a new sonic brush that makes amazing claims, but I have no idea how good it is
https://uk.emmi-dent.com/
I'll ask my hygenist tomorrow, but given she hadn't heard of a WaterPik...
I had an inexpensive powered brush at one time but I destroyed it because I couldn't keep it clean. I'm hoping that more expensive also means better quality.
It looks like the Oral-B Triumph series isn't available in Canada but there Professional series looks similar so I'll look into it further.
Thanks for the help so far.
I'm in the market for a new toothbrush
Looks like the Oral-B Professional and Sonicare are pretty much the same.
Planning on ordering a Sonicare HealthyWhite very soon
I know someone who has one and loves it.
I have the Oral B 5000, and it is so much better than a manual tooth brush.
My ortho gave it to me. It comes with a timer, that senses how long and how hard you are brushing. It is rechargeable. And, I took it with me on a trip from MA to FL, didn't charge it,for maybe 3 days and used it, 3x a day. It works wonderfully, for me! Love the clean feeling I get, after brushing with this tooth brush. Will never go back!
Thanks! I've been looking at that one. Amazon has a very good price for it. A long time between charges is a big benefit to me as there isn't any room in my tiny bathroom for the charger.altesse7 wrote:I have the Oral B 5000, and it is so much better than a manual tooth brush.
Thanks for the feedback.
Sure! It's an amazing toothbrush!
- parsleysage
I have the Oral-B Triumph 4000. It was $45 dollar cheaper than the 5000 and the only difference seemed to be a little wireless "smart brush" thing that showed a timer of how long you were brushing. (Doesn't make sense cause the brush already beeps when it's time to stop/change quadrants... even though it looked cool in a YouTube vid I saw, it didn't look $45 worth of cool!
I've read that the oscillating brushes are more effective than the vibrating sonic brushes, but really if you are brushing at least twice a day you're ahead of a lot of people already! After that it would just be a contest between great and excellent.
I like my Oral B Pro.
I guess I should have posted an update. Sorry.
I ended up getting the Oral B Professional 5000. After using it for about three weeks I've developed a bit of a love/hate relationship with it.
On the positive side, there is no question that my teeth are cleaner. It's doing a very good job of keeping the plaque buildup on my lower incisors in check.
On the negative side, the sonic action gives me a bit of a headache while I'm brushing. Fortunately, the headache fades quickly after I stop.
For Canadians thinking of buying this brush, the best price was on Amazon.ca.
