Is it okay to use a little bit of ACT Mouthwash after brushing your teeth
after everymeal or snack. I use the amount at night and morning that your are surpose to use, but when I eat or snack just wonder if I can do a little bit of a swish with mouth wash not the full amount just a bit.
It does make your mouth seem extra clean....
Mouthwash
- Kinda Nervous
Mouthwash
<a href="http://www.TickerFactory.com/">
<img border="0" src="http://tickers.TickerFactory.com/ezt/d/ ... t.png"></a>
Listerine whitening mouthwash
Is it ok to use Listerine whitening mouthwash with ceramic braces?
50+ ceramics top and bottom as of 2-16-10
Scheduled to have braces removed on 8-16-12!!
I wouldn't use any whitening anything with braces....you risk all the areas around your brackets to get supper white, so when they take your braces off you will have discolored spots because that part didn't get whitened.
Wait until after they are off to whiten, if at all...so they can all be the same color.
Oh, don't rinse with flouride rinse more than once at night, use something else during the day.
Thanks Theresa48
I haven't used it very much - so I'm sure it won't make much difference, but good point and well taken.
