Ok i know this may seem silly and all, but.... I was given these because i clench my teeth together. I was told these are used to help. But am i to heat them in water and let them shape to my teeth? Or just use them as is.... Im not sure... Anyone else out there use these??
(Also, there are two showing, i just placed them like that to fit both in the pic.... im sure i only use one at a time of course)
What is this???
What is this???
If you're on the ride, you might as well open your eyes!
Banded: Dec 24, 2004
Your post is a few months old, so you've probably already found out what these are for, but just in case you haven't here goes. They are for you to bite down on when your teeth are sore - it really helps, and no, you don't heat them up, they don't mold to your teeth - they're like adult "teething rings!" Cheers, BHW
For the interested crowd...
They are called therapy bite wafers:http://www.jawproducts.com/therapywafers.html
Helen
Helen
