Biting the back of your cheek with retainers?
drgnchsr36
#1 Post by drgnchsr36 »
I seem to have this issue while wearing the retainers of biting the back of my cheek at night. It's becoming a common occurrence and it's annoying me. Plus, I heard it could cause oral cancer if I continue doing it. I'm thinking of seeing my ortho again and asking about it. Maybe I should just wear a mouth guard? Would that help? I'm just not sure what to really do..
djspeece
Re: Biting the back of your cheek with retainers?
#2 Post by djspeece »
I don't think mouth cancer is likely, but I would recommend that you go back to your ortho -- you didn't mention what type of retainers you use, but perhaps they can be adjusted or modified, or the ortho may have some other tricks up his/her sleeve. Don't wait until you end up with some sort of infection -- and of course the more this happens, the more swollen the tissue becomes, and the more likely you are to chomp down on your cheek. Best of luck to you.
drgnchsr36
#3 Post by drgnchsr36 »
Thanks! I did ...ended up getting a mouth guard. I’ll probably go back and forth between that and my hawley retainer
