essix retainers and heat
litenight
#1 Post by litenight »
Hello guys! So I wanted to know what temperatures are generally required to warp or ruin essix retainers. I am asking this because I accidentally left my retainers right beside the cooling fan of my laptop. The retainers were in their case. When I put them back on they seemed to fit properly, but still I am worried I might have ruined them.
Rebeccasmells
Re: essix retainers and heat
#2 Post by Rebeccasmells »
Yeah you've probably ruined them, after all they don't fit now and have visible damage. :gavel:
Just kidding it's plastic, chill.
bbsadmin
#3 Post by bbsadmin »
In general, you should keep them away from heat sources (out of hot sun in your car or on a window ledge). I don't know what temperature it would take to warp them, but I think that normal situations would be OK. Think about how intense it has to be in a microwave to warp plastic!
