Tooth is shifting out of alignment
Marigold
#1 Post by Marigold »
I have a front bottom tooth that is rotating slightly and I can feel the edge stick out. Has anyone had teeth move after debracing, and what did your ortho do about it? I only have to wear my Essix retainer 1/2 days now but I'm wondering if I should go back to full time. I dread calling my ortho about this.
Class II moderately deep overbite, mild crowding.
Braced on January 19, 2011. Debraced on December 16, 2013.
2 years, 11 months in braces.
jem
Re: Tooth is shifting out of alignment
#2 Post by jem »
If I were you I would contact my ortho asap. If you act quickly it may be possible to get that tooth back into place with a different retainer or full time wear of your current retainer, whereas delaying might mean the tooth moves too far and you could be back into braces. And I would go back to 24/7 wearing of the essix pending seeing the ortho.
Good luck and keep us posted
Jem
