I have bonded top AND bottom retainers. I need the bottom essix because I have two spaces in my lower arch where I had extractions. One space will be replaced with an implant - the other space, not sure. Too late for an implant without a bone graft which I do not want so unsure what I will do there. Choices are a bridge or wear a removable retainer forever. The essix is being used so my teeth do not shift into those spaces and throw off my bite again. My plan is to go for the implant in a few months. I'll need my retainer adjusted as the implant process continues.
ANYWAY - my essix HURTS big time. When the ortho placed it on my lower teeth for the first time he could not get it out without causing me a great deal of pain. He said he would adjust it - which he did and then put it in again. It was a bit easier to remove but still not great. He told me to begin wearing it as soon as possible that night and it would get better as my teeth when back into place.
It's been 5 days - it still hurts when removing and is quite tight. Is this normal??? I also have one tooth that throbs after I take it out for a while. It is a tooth that is directly infront of the gap where there is one tooth on one side. I'm sure this is a rare case I have - most people probably have all their teeth when they get their retainers.
Aren't there any other kinds they use these days? When I had braces many years ago we had different types of retainers - were those Hawley's? He said these are much better - but boy they were sure easier to take out and did not cause the pain!
I return to the ortho for a re-check in 5 weeks. I'm sure what I'm feeling is pretty normal - just wondering what others have gone through. I did search for similar topics - not finding anyone that has spaces though after brace removal.
Thanks!
