Gum Recession due to Bonded Retainer??
ktr78
#1 Post by ktr78 »
I have had a bonded retainer on my upper front 4 teeth for about 6 months. I've had a sensitive gum line on those 4 teeth since lately. When I take a mirror to look at the back of my teeth, I see that my gums have receded into points. The glue holding the wire on my teeth is all the way at my gum line and I believe it is causing the problems I am having.
Has anyone else experienced this? I want to get the whole thing removed but worry my teeth will not be stable without it. My teeth were very loose when my braces came off.
ktr78
Re: Gum Recession due to Bonded Retainer??
#2 Post by ktr78 »
No responded to my post but I wanted to give an update in case it can help others in the future. At my ortho appt this week, I mentioned my concern and ortho said the glue could definitely be irritating my gums. He scraped away some of the extra glue at the gumline. Took 2 mins. My gums feel much better now. Easy fix.
