How do you clean your retainer?
luchababe
#1 Post by luchababe »
I've noticed plaque build up on a few spots on my removable retainer. After some Googling it seems soaking it in a 1/2 and 1/2 solution of water and vinegar is most common. I was told to NOT use a toothbrush to clean it since it might scratch it and those scratches will gather bacteria which will stink, etc etc. The cleaner that starts with the letter P that has been used in spam posts, so it's censored. was also recommended but I don't see that taking off the hard plaque gunk.
So I'm looking for some suggestions!
I'm going for a dental cleaning in 3 weeks so I think I'll take my retainer in with me and see if the hygienist can either scrape it off for me or suggest something I can do.
luchababe
Re: How do you clean your retainer?
#2 Post by luchababe »
In case anyone reads this post, I tried the 1/2 and 1/2 white vinegar and warm water idea and it worked pretty good. It loosened the plaque so I could gentle rub it off with my finger. A few more soaks and it should be quite clean.
loradora
#3 Post by loradora »
My ortho instructed me to soak them in vinegar/water once a week for about an hour.
bbsadmin
#4 Post by bbsadmin »
The vinegar and water won't stop the plaque buildup. For that you need a professional strength retainer cleaning product, such as Retainer Brite, SonicBrite, Cleanse Freshen Go, or DentaSoak. You can find all of them at DentaKit.com.
Do not use denture tablets; they will eventually turn your retainer yellow.
smartygirl
#5 Post by smartygirl »
do you know if there are any canadian sites carrying these products? dentakit charges $30 to ship!
the comeback kid: my blog about braces, asthma, and a broken foot.
smilezofmetal
#6 Post by smilezofmetal »
Have you tried denture soaks...that's what I use.
BracedSurgeryStudent
#7 Post by BracedSurgeryStudent »
I was told: NO denture OR retainer cleaners at ALL. Use a hard bristled toothbrush cold water ONLY, no warm or hot water, and no soaking it in hot water or boiling it.
Jenn Medeiros
lana23
#8 Post by lana23 »
My ortho recommended Efferdent denture tablets so I went out and bought a 6 month supply. When that runs out, I will give the Retainer brite a go.
cs2thecox
#9 Post by cs2thecox »
I have Essix-type retainers and was told to use a normal toothbrush and no more than warm water. I guess hot water softens the plastic again, and changes the shape! Definitely no abrasive toothpaste either.
I was also told that denture cleaning tablets are fine to use. (Or specific retainer ones - I got a free sample of RetainerBrite or something.)
I only have to wear my retainers at night (I have permanent bonded wires top and bottom too) so it doesn't really matter if they go a bit yellow!
Roses
#10 Post by Roses »
I was told a soft brush and cold water whenever I take it out for food/before bed/to freshen up and then use a denture cleaner regularly, but the one I have been using from boots is 90p for a months supply so I've been using it every day
phasesofbeauty
#11 Post by phasesofbeauty »
I have clear Vivera retainers.
I brush them thoroughly with liquid soap and water at least once a day.
Helpful Information to Make Your Life More Frugal and More Fun!
https://krystalbrownblog.wordpress.com
cs2thecox
#12 Post by cs2thecox »
Roses - totally agree on the Boots denture cleaner. Fairly sure it comes out the same factory as Steradent etc and it's an absolute bargain!
I used it on my night guards for years before I got braces and never had any problems.
(Although being a bit more careful with water temperature and my retainers!)
plugnickel69
#13 Post by plugnickel69 »
I was told very soft brush that they use at the ortho's office and antibacterial liquid soap. Seems to work. Been doing that successfully for a year-and-a-half.
retainerjoe
#14 Post by retainerjoe »
DAWN dish soap, put water in a cup enough to cover them add about ten or so drops of soap mix add retainers , just like soaking pots and pans , cheap works great :jump:
http://community.webshots.com/user/head ... =community this link also has my video of me getting my braces
plugnickel69
#15 Post by plugnickel69 »
DAWN, interesting. I used to work with a guy who used DAWN to clean his contact lenses.
