I had permanent retainers applied last week and the glue (on the bottom one, at least) has stained yellow already.
Should I be concerned?
Additionally, how do you floss around them?
Glue stained/flossing around permanent retainers
Re: Glue stained/flossing around permanent retainers
You floss above the wire like normal. To get underneath the wire you need floss with a stiffened tip and push it in at the gumline.
About a minute into this video it demonstrates flossing:
http://www.youtube.com/watch?v=Aox2MwH2hzA
I think they sell special floss for this.
