Bonded Retainer Question
tinkerbelle216
#1 Post by tinkerbelle216 »
Hi all its been a while since I've posted and I figured I would come back after being away.
my darling boyfriend wore braces early in his childhood and has had them off for some time. He has a lower permanently bonded retainer and I noticed something about it and wanted to know if it was supposed to be like this.
Is the bonded retainer wire supposed to be straight along with the arch at the back of the teeth? I noticed that darling boyfriend's retainer is curved and bent in certain spots and it doesn't look "right" to me. I've seen lots of patients come into the office I work at (I'm a dental assistant) with bonded retainers and they've been straight with the arch and didn't appear the way his does.
Just thought I would run it by you guys.
Thanks
Pixie Dust,
Meredith
Zeppguy73
#2 Post by Zeppguy73 »
No clue. Unless the ortho felt it necessary to bend the wire in different places to put downards or upwards pressure on certain teeth to prevent motion the other way. Other than that, I would assume that is irregular
Miss Smiley
#3 Post by Miss Smiley »
Mine is kind of bent in certain spots. It just looks like a wire that was bonded with out the mesh pads at the ends.
Est. term: 30-36 months
