HELP! Freaking out...
acrowell
#1 Post by acrowell »
Hello, I've had my braces off for three months now. I wear the Invisalign-type retainers at night.
The reason I had braces put on (for the second time...) was that my bottom teeth in the front had become very crowded, and they're the teeth that did the most movement in the 15 months I had braces.
They're straight again now but still very close together, two teeth in particular, and one of them still feels loose. It's not actually wiggling around, but I can see a tiny bit of movement when I push against it with my fingernail.
Is this NORMAL, three months after having my braces off?
