That's pretty neat. Did you take those pictures yourself, or were they done at your ortho's office?
About that once-wayward tooth on your upper right...about how long did that take to move into the proper position? I'm curious because I have two bottom canines that need to be moved some distance like that.
The wayward tooth took about 7 months to move enough to look normal. At the one year mark it had reached its final position. It is still not perfect. This is why I wear a positioner now.
BTW Don't look for a midline. I don't have one because I miss a lower lateral.
Before morphing you should prepare the photos by stacking them one on top of the other (by the layers feature in photoshop) so the back teeth will fit.
