Hello:
My midline looks fine between my upper and lower central incisors but it is off-centered from the center of my nose. I don't care for this at all. What should I tell my orthodontist?
Midline from center of nose
Re: Midline from center of nose
Maybe that will get better with braces specially if you have gaps or overlapping teeth. However if you don't mind then you should be fine unless your ortho sees a problem with it or is very picky..if so and if its an easy solution id say you should consider it.
Perhaps you should just inform the ortho that its not something you mind at all. I doubt its noticeable to anyone other than yourself and you're opinion is the one that matters anyways.
If youre happy with your smile whether lopsided or not, then it doesnt need to be changed, i reckon?
Hows your facial structure, knowing your midline is off centered? Just curious as i have midline problems too
