I had one fall off today and was told come back in a week???
Seems like a long time but it is my next appt. I guess they
feel I will have my for at least two years what's a week? Now I
will be longer with my treatment. ERR.. Not to happy about that.
How do you keep bracket on a crown
- Kinda Nervous
<a href="http://www.TickerFactory.com/">
<img border="0" src="http://tickers.TickerFactory.com/ezt/d/ ... t.png"></a>
I have two brackets on crowns and both have stayed (knocking on wood). They scraped/etched the crown slightly and used a special light to cure the cement. I was told that there was a chance it wouldn't take the first time and a chance they'd come off later. So far (4 months) so good. So, perhaps when they re-adhere yours, it will stay put. Best of luck.
How do you keep a bracket on a crown
I have a crown and a molar band, with bracket, on the crown. The ortho said that it would be too difficult to attach the bracket to the crown otherwise - meaning to get it to stay on.
I, too, had a bracket come off after about a week. It was placed on a porcelain crown, and I was told that there was a good possibility it would come off, but they wanted to try anyway. I went in a day after it came off, and they did something to the surface of my crown and re-glued it on. So far, over 2 months later, it's stuck on there pretty good.
My silver molar crowns, however, had to get banded because there was no way he could get them to stick on there.
