Stained teeth due to overlapped teeth
chinglnc
#1 Post by chinglnc » Sun Nov 19, 2017 12:19 pm
Hi
My overlapped teeth have 'pushed out' more since I started the invisalign treatment, and I can see the 'stained mark' on those overlapped areas of the teeth that used to be hidden.
My question is, what do you do with those stained area? Do they disappear overtime with brushing or do I need special cleaning/whitening to clean them?
Thank you
assertives
Re: Stained teeth due to overlapped teeth
#2 Post by assertives » Mon Nov 20, 2017 6:29 am
You can schedule a cleaning at your dentist. The stains should come out.
