Tooth Shaving
mcfly24
Tooth Shaving
#1 Post by mcfly24 »
Hi Everyone,
New to the boards here as I'm on tray 2 of my 18 tray treatment plan. I'm doing this through my dentist and as she showed me the digital plans there was a section about 'teeth shaving' where 0.3mm was to be shaved from the sides of a few of my bottom teeth where crowding is. My question is, is this common? and how painful is this procedure?
Thanks
FlyByNight
Re: Tooth Shaving
#2 Post by FlyByNight »
Interproximal reduction (IPR). No pain. Maybe a little sensitivity but I had it done to remove black triangles. I had no pain or sensitivity but everyone is different. The gaps closed up in a few weeks.
Aaeolien
Re: Tooth Shaving
#3 Post by Aaeolien »
Girlfriend just had all her bottom teeth done a bit at her last appointment to make space. Just a bit of soreness afterwards (could've been new tray pain as well). Little Ibuprofen and problem solved. Not a big deal at all really.
inkygirl
Re: Tooth Shaving
#4 Post by inkygirl »
I had my bottom teeth shaved to widen the gaps between them. I'm usually super-sensitive to tooth/gum pain but apart from the "this feels super-weird" sensation, it was no problem. No soreness after, either. Like FlyByNight, my gaps closed up in a few weeks.
liner
Re: Tooth Shaving
#5 Post by liner »
no pain at all and yes very normal.
DrJasonKTam
Re: Tooth Shaving
#6 Post by DrJasonKTam »
If done properly, there should be no sensitivity or increase the predisposition to cavities. You don't need any needles for this procedure either. We've put together a video outlining IPR (inter proximal reduction) / shaving / slenderizing / filing. Hope this helps! http://www.torontobraces.ca/gettingstarted/#4
Dr. Jason Tam
http://www.mcosmiles.com
dyna
Re: Tooth Shaving
#7 Post by dyna »
Are there any scientific articles about the predisposition to cavities due to tooth shaving?
Speck
Re: Tooth Shaving
#8 Post by Speck »
The orthodontist in charge of my treatment performed IPR on quite a few teeth both top and bottom (lots of crowding) and the procedure wasn’t a big deal. However, breathing the enamel dust is something to avoid, mostly because of the unpleasant odor. I suspect most orthos will be conservative with IPR simply because enamel is very important and once it’s gone...
