Can you use efferdent power clean crystals
bajusbeach
#1 Post by bajusbeach »
Can i use the Efferdent Power Clean Crystals to clean my invisilign braces. Has anyone used this ? I have not used this but even though I brush with antibacterial soap the odor is still there. I brush and floss three times a day too. :!:
bbsadmin
Re: Can you use efferdent power clean crystals
#2 Post by bbsadmin »
No, it is NOT a good idea. Efferdent is a denture cleaner, not a retainer cleaner. It will eventually yellow your retainer.
phasesofbeauty
#3 Post by phasesofbeauty »
I have done this but I don't do it everyday.
I know this is not recommended but since I am changing the trays every two weeks, I don't think it is a big deal.
I certainly won't do this when I am done with Invisalign and I start with retainers because I will have to keep my retainer for much longer than two weeks. (yes, I know that was a run-on sentence)
:D
I brush my trays with water and liquid soap to clean them. I only do the Efferdent about every three days. I soak them while I have breakfast.
Also, I use the regular Efferdent...not the power clean one if that makes any difference.
I have no issues with odor at all.
Helpful Information to Make Your Life More Frugal and More Fun!
https://krystalbrownblog.wordpress.com
lauraes
#4 Post by lauraes »
I use these, and I don't have any problems with yellowing of the trays. They're still very clear, no cloudiness or yellowing, at the end of 2 weeks. I soak the aligners in the crystal solution in the morning while I eat breakfast and clean my teeth, then rinse them off and brush them in water before putting them back in. The rest of the day I just soak the aligners in water whenever I take them out to eat and give them a brushing under running water.
