Newbie needing help - Invisalign THEN braces
DrJasonKTam
Re: Newbie needing help - Invisalign THEN braces
#16 Post by DrJasonKTam »
I think the main thing to understand is that the majority of the people posting here are going to be posting problems rather than successes. The biggest thing about Invisalign treatment is that you choose the doctor to do the Invisalign. You're not buying Invisalign as the results you are going to receive at each doctor will turn out differently.
Assuming you have chosen an experienced Invisalign provider, you should be able to achieve the results you are looking for, if the doctor has told you that Invisalign is an option. Good luck!
Dr. Jason Tam
http://www.mcosmiles.com
