Wha is a "virtual C chain"?
turbocycle
#1 Post by turbocycle »
I'm almost completed with my treatment, but I have a bit of a gap between two teeth where IPR has been done throughout my treatment.
My dentist said i may need a "virtual c chain" to correct the gap.
What is that?
Thanks!
DrJasonKTam
Re: Wha is a "virtual C chain"?
#2 Post by DrJasonKTam »
It's a complicated way of saying aligners that will help close your spaces like a power chain would with braces. Sometimes these are done in overcorrection aligners that are preplanned. Other times, it may need to be done with refinement.
Dr. Jason Tam
http://www.mcosmiles.com
ohioinvisguy
#3 Post by ohioinvisguy »
I believe this is what I had at the very end of my treatment with invisalign. My ortho removed a section of my last few aligners starting with my premolars and ending with my second molar. This closed up my spaces perfectly! Hopefully you will get great results too!
Check out my Invisalign Bog at http://invisalignadventure2010.blogspot.com/
