I am a serious tooth grinder/clencher and have to wear a mouthpiece at night. Initially I had one of those hard ones, but after breaking it twice, I switched to a rubber one, which works well.
I am set to get my aligners next week. I am a bit worried that I will clench the aligners and break them during the night. I was only going to do the top, but later decided to use Invisalign on both top and bottom teech, so I won't be able to wear my mouthpiece at night.
My dentist didn't seem to be concerned, but I'm scared that I will bite right through these aligners. Has anyone had this problem?
Any Tooth Grinders Using Invisalign?
I am a hardcore clencher and I do grind my teeth at night as well and I have had no problems whatsoever. No rips, holes, I haven't ground through the aligners or come close to it. They are sturdier than they look, trust me.
My Invisalign blog ~>http://upsanddownsintheothersideofthest ... gspot.com/
Teeth Grinding
I am on #7 of 10 trays and have had no problem with grinding. No breakage, etc. They are alot tougher than I expected.
Grinding isn't a bad thing!
Using Invisalign, you don't have to worry about grinding. The trays are quite strong and used for only two weeks at a time. We have some severe bruxers who have not had any problems with the trays.
In fact, patients who grind their teeth are actually good candidates for Invisalign since there is full coverage over the teeth. Hence you won't be using a night guard during your treatment. The fact that they are constantly biting into the aligners means that there is more likely a snug fit. This is a similar effect to using the aligner chewies.
Dr. Jason Tam
http://www.mcosmiles.com
