Has anyone notice a speech difference since starting their invisalign.
Prior to my invisalign I had (and was told) a very siglht lisp, now that has all but dissapeared. Has anyone else ntice a difference with their speech??
Speech difference in invisalign
You are very likely compensating for your speech production, and being more precise in you tongue movements. This is what a speech pathologist would get you to do to correct your lisp, so the aligners have likely created enough of an "irritation" that has made you alter your movements. An added bonus for you!
19 upper, 26 lower. Started with trays Feb. 18, 2008
I had a slight lisp and it was bad since I work as a radio DJ. I was stubborn enough to not take my aligners out and now I speak normal. I adjusted my speech and have almost perfect diction again
Orthodontics patient from 2007 to 2010.
Orthodontic Braces
Orthodontic Braces
