Effects of mouth breathing .
Tyfreeman6
#1 Post by Tyfreeman6 »
How Mouth breathing effects the face ? I use to breathe through my mouth as a child . So I have a long narrow face . With a skeletal open bite .
Nozzelnut
Re: Effects of mouth breathing .
#2 Post by Nozzelnut »
You pretty much covered the biggest issue; but there's more to it; a forward position of the head in relation to your neck. Remodeled airway because of that. Narrow nasal passages due to narrow upper arch. There's a few videos out there if you want to do more research.
Round 3 (lifetime) Invisalign treatment started 2/26/20. Estimated 9-14 months.
Upper ceramics 5/21/14, Lower stainless 5/28/14
Double jaw surgery was 6/18/15. Estimated time Jan 2016; still on at my 2 year anniversary...
Braces removed 7/20/18; upper and lower Hawley and Essix retainers with bonded lower too.
Tyfreeman6
#3 Post by Tyfreeman6 »
I've stopped the mouth breathing . But is it true that the only way to fix my teeth/jaws would be with braces/surgery ?
assertives
#4 Post by assertives »
The treatment options available depends on the severity of the issue, age and will also vary from person to person. I'm no professional, but I would say though, if you are past 18, I'm afraid surgery may be the only answer if you have some kind of skeletal discrepancy.
Your ortho and or surgeon would be able to give you a treatment plan and or options after they have examined you and taken some diagnostic tests and xrays. You should discuss this with your medical team if you haven't already.
Tyfreeman6
#5 Post by Tyfreeman6 »
Surgeon said it's a dentofacial !
