dry cracked lips
dry cracked lips
i am just about 4 weeks post op and my lips are so sore and dry and cracked mostly in the corners,,,,over the counter lip balm seems to no lnoger be working since i needed it so much in the beginning after surgery....
anyone have any ideas?
I've found that anything that contains petroleum ultimately makes my lips drier in the long run.
For me, the balms that consist of natural oils work a lot better...such as Burt's Bees, or even better is Noah's Naturals(can buy it at wal-mart)
October 8, 2008 Lefort1(6mm impaction), BSSO, Genioplasty, Turbinectomies, Partial septoplasty, gum recontoring
Bag Balm
This may sound a bit bizarre, but I found a lot of people (including myself) to use a product called, "Bag Balm" for chapped lips. The product is used for cow's teats to soothe sores, cracking, etc.
One of the nurses I work with purchased them at an animal feed store. However, you find them at pet stores, farm stores, hardware stores, and tack shops (in addition to the internet of course). It's almost like petroleum/vaseline, but it's slight less glossy and smooth. I actually prefer Bag Balm much more. Plus for 7.99, for 10 oz? It'll last years!
So the saying goings, "smooth as a baby's bottom". "My lips are as soft as a cow's teat".
I was given a lip balm that is used for people that undergo radiation therapy. It helped the most compared to others, but if I didn't apply it constantly I would end up with pieces of dry lip skin just hanging. Had to cut some off with scissors (gross I know, but better than pulling, which I did once and it hurt like %$(&)
Here is an article which advises shea butter for dry lips, and it explains why petroleum products can dry your lips more which may be the reason why the over the counter balms you've been using aren't working:
http://health.learninginfo.org/shea-butter.htm
Also, I haven't tried it yet, but castor oil is supposed to be the best remedy out there for dry lips.
