I have a question...
I'm supposed to get started on an antidepressant soon, and I'm also expecting to have surgery sometime late next month. Is it OK to start taking meds before surgery like this? I'm worried it's going to somehow interfere with all the surgery-related meds I'll be having to take and also the anesthesia. Is it worth putting the antidepressants on hold til after surgery?
medications & surgery
Id just make sure you tell the anesthioligist as Karl says, last thing you want is them postponing the op.
I was on anti anxiety drugs before op, and they were fine, tho did have a few side effects with pain relief, so definately check in advance.
