Is tooth shaving included normally
My ortho indicated that she would like to shave some of my teeth to make them narrower. This is fine with me, and I've seen many posts from other people on this forum that had it done as well.
My question is, is this normally covered as part of the treatment?
The reason I ask is that during my dental check-up, my dentist offered to do it. I would expect to need to pay him, whereas my ortho would have done it for free.
I want to be armed with information before he steps forward and asks me to pay him. I'd rather have her (my ortho) do it for free.
I supposed a 2nd question would be wheter or not dentits or orthodontists are typically better at this. I personally wouldn't think it matters.
Thanks,
Ted
Thanks,
Ted
I too would like to have it done. So I mentioned it to my ortho, and he said he'd like to wait til I'm further along in my treatment. So I know that he does it, but I'm not sure if it will require additional cost. I'm going to guess and say, no it doesn't. From all the others that mentioned it here, I can't remember anyone saying they paid additional money.
I have my teeth "slenderized" at each ortho visit. Just the lowers to make room for a wayward tooth. Also a spring is there to help make room.
It is included in my total price.
Good luck
Good luck
~Lyn
16 months in BRACES!
Ceramic Braces on top 7/3/05
Metal Braces on bottom 10/25/05
OFF 11/8/06 - Now in Essix Retainers 24/7
My ortho did the service for free. It doesn't take all that long and it didn't hurt at all. The only thing that sucked was the spacers I had to deal with in preparation
With that said I would say DO NOT under any circumstances let your dentist do this unless he is somehow in touch with your ortho. This is no way your dentist would have any idea as to what your ortho has for the final plan on your teeth (ie - what he makes straight now can be crooked when your treatment is finished).
Mike
3M smartclips top and bottom since 10/13/04
Off November 06!
Off November 06!
In my case, the dentist and ortho are in the same building and although each one is technically an independent contractor, they all work together as one practice.With that said I would say DO NOT under any circumstances let your dentist do this unless he is somehow in touch with your ortho.
However, I think I agree with your second point despite having the dentist nearby, the ortho has the best understaning of the treatment and the final results.(ie - what he makes straight now can be crooked when your treatment is finished)
Thanks for your post.
I believe that the tooth reshaping and any slenderizing that I might need is included in the treatment cost.
I agree that you should have the ortho do it, and not your dentist. Your ortho will want to be precise with any slenderizing for the best possible outcome of your orthodontia.
If your still concerned, call the orthodontists office and ask. I am sure that they will be happy to answer any questions for you.
~*~ Kim ~*~
Next Appointment #14: Feb 26,2007
Shaving teeth
My ortho would rather shave a tooth down than extracate. He hates to remove the teeth unless it is necessary. I am going to have to have a few shaved to make room for a wayward virgin tooth (I am 42 and this tooth has never been in contact with an upper tooth). This is included in my treatment plan but I am not sure when it will be done. I will check on my next visit on March 7 when the bottom braces are placed.
I am glad I found this. I was wondering what was meant by "recontouring" and the black spaces. I don't know why I didn't think of this earlier--I was assuming it meant something like a stain-per se.My dentist/ortho has slenderized both top and bottom front teeth to eliminate the "black triangles" (spaces) by the gumline and it was no extra cost. Then when I'm all finished and braces come off he will even out all the front teeth on top and bottom (horizontally).
I believe I will getting this done at some point.
