What does power chain do?
Snow
#1 Post by Snow »
Hello,
I had my fourth adjustment yesterday. The ortho put one power chain on half of my top teeth, and two separate chains on my bottom teeth. Wonder what kind of job power chains do? From what I read from other posts, it seems to be used to close gaps. Though I do have one extraction gap on my bottom right, I don't have gaps on my bottom left or top. So the power chains must serve other purposes. I kind of hearing the ortho saying "start rotating" to the techniician, but I am not sure this is what he is trying to achieve with power chains. Wonder if anybody knows what kind of work power chains do? Thank you.
Spacers in: 7/20/2005
Braces on: 7/27/2005
Clear braces both top and bottom
Treatment time: 18-24 months
Braces off: 7/26/2007
TheSilverSmileChileno
#2 Post by TheSilverSmileChileno »
he maybe but a powerchain in the other side to keep those teeth in their position when the other powerchain closes your gap.
or not? :?
Spacers-7-27-05
Full Braces on-8-15-05
I luv my braces...
hannah164
#3 Post by hannah164 »
I have powerchains over my extraction gaps to close them but I've also had a huge grey powerchain used to rotate certain problem teeth!
That might be what it is used for! :?
Good luck! :frogbraces:
Top braces: 4/28/04
Bottom braces: 11/16/05
Next Adjustment was 1/11/06 but now is rescheduled to 1/21/06
fins
#4 Post by fins »
I think they are also used to keep gaps from forming between teeth (holding teeth together).
