off midline?
off midline?
How do they correct an off midline? When i first started, my midline was perfect, but now it's off a bit, so i was just wondering how they were going to correct this? I am thinking elastics, but i might be wrong, any replies are much appreciated!
Shelby
Shelby
O.o*Shelby*o.O
braced on:9-29-05
http://tickers.TickerFactory.com/ezt/d/ ... /event.png[/img]
braced on:9-29-05
thanks much, mine isnt off that much, but i just hope that they dont saddle me up with a power chain AND elastics.....that would hurt really bad.
Thanks guys!!
O.o*Shelby*o.O
braced on:9-29-05
braced on:9-29-05
Hi there!
I always have no-simmetry in the midline, I need to push everything to the left, but when I started the treatment the midline was worst...
My ortho said that we need to fix something before correcting the midline, he will put a spring between the braces to start moving things.... and also some elastics....
cheers!
cheers!
I'm glad someone brought this up. I've had no midline problems ever....until now. I got my first powerchain last adjustment and holy smokes, my midline is so off now! It's almost a whole tooth off like yours, Karen. Scared me for a bit there. I must say though, the powerchains have done what they're supposed to do as I have noticed quite a difference in my gaps. Woohoo!
a WHOLE TOOTH? wow, that like a huge difference. Mine is off like .5 of a mm or something. Not that bad though. I hope i get something "new" next adjustment. I mean I want something a little more exciting then a wire change and lig change.
O.o*Shelby*o.O
braced on:9-29-05
braced on:9-29-05
midline
Mine is being corrected with elastics. It's not very attractive but it seems to be working really fast. sorry for the blurry picture, but you can get an idea.
best wishes,
leah
[img][img]http://img357.imageshack.us/img357/6104 ... eth2sv.jpg[/img][/img]
best wishes,
leah
lower wisdom teeth cut out 1/27/05 (ouch)
braced 3/8/05.
24-30 month Est.
going full metal 8/22/05
Naked as of August 28, 2006
braced 3/8/05.
24-30 month Est.
I noticed a few days ago the same thing. My midline is slightly off where it wasn't before. I couldn't wait to get back to my internet connection at work to ask the exact same question.
I have a spacer spring which I'm sure is what is causing it to move, but I also just had my wisdom teeth out so I'm hoping that maybe there is room back there to shift everything back around.
Another question. I don't have bottom braces, so I can't use elastics, can I? How would they move it then? He is NOT leaving it this way...
Then again, there is a SLIGHT possiblity that it only seems to be off because I'm having to move my lower jaw to the side slightly to get my teeth to close (that canine sticks down funny, where it will come over my lowers when it is in place.)
wow, i hope that i dont have to wear elastics like that, how do you talk with those in? About when do they start you on elastic treatment? I'm really hoping for something new at my next appointment! Lolz.
O.o*Shelby*o.O
braced on:9-29-05
braced on:9-29-05
