Has any one experienced this type of pain before?
Loop
#1 Post by Loop »
I sat down to eat my dinner the other night and out of no where I got a severe neuralgic pain on one of my lower molars. Ever since then the pain has been getting steadily stronger and getting triggered more frequently.
It is nothing like the pain you experience after an adjustment, the closest thing I can describe it to is a sensitive teeth kind of pain but the most severe form I've ever experienced. There is a second or two delay before I feel the pain then it builds up and spreads along that side of the lower jaw before finally subsiding about 5 seconds later.
The strange thing is, if i bite down on the tooth it doesn't hurt at all but if I'm trying to eat, it is really painful as though the hot/cold triggers it off, also a cold draft and brushing my teeth triggers it as well.
I just wondered if any one else had experienced this and if it was something to do with my braces or if I need to book into the dentist.
Nikkiekoala
#2 Post by Nikkiekoala »
I have had that kind of pain before. It was miserable. I needed a root canal to fix it. It happens when decay reaches the pulp of the tooth. Go to the dentist hopefully you will get it early before needing a root canal.
Braced Aug. 11th 2005
Damon 3's
Crowding
Crossbite
**My Website: http://nikkiekoala.efx2blogs.com/
doglover1395
#3 Post by doglover1395 »
This sounds a little bit like a pain that I get in one of my molars. Mine does not get worse though and is not triggered by hot or cold. It only hurts when I floss. It has actually been geting better. I'd say that if it keeps getting worse you should talk to your dentist. Hope you feel better!
Braced: 3/4/05
Debraced: 5/21/07
Sentence: 26 months
