worried about permanent retainer
Fiatbraces
#1 Post by Fiatbraces »
I finally got my brace off today and had a permanent retainer fitted anyway I just ate and bit into the retainer, the permanent retainer seems to still be in place but slightly worried I may have damaged the permanent retainer , would I know if the permanent retainer came loose or had been damaged?
Mpkh
Re: worried about permanent retainer
#2 Post by Mpkh »
You will know if the permanent retainer is damaged or loose—you will feel it come loose and the tension it provides will not be the same.
Braced: April 07, 2017
Debraced: February 08, 2019
Sentence: 18-24 months
Actual time in braces: 22 months and 1 day
Reason: Straighten teeth, correct crossbite and edge-to-edge bite
http://myjourneyandlifewithbraces.blogspot.ca
Fiatbraces
#3 Post by Fiatbraces »
Mpkh wrote:
Tue Apr 09, 2019 1:49 pm
Thank you, this has put my mind at ease!
Fiatbraces
#4 Post by Fiatbraces »
Hi this morning I brushed my teeth and bits of glue come off the back of my teeth, is this just the residue from having the retainer fitted? Thanks
