Extraction gap closure time
Hi. What are people's experience of the time taken for extraction gaps to close? I've had 2 top teeth out, 5th in (sorry don't know technical terms) and was just wondering. It's been 3 months and I reckon it's a third closed. Just moved off round wires onto square. Thanks
Re: Extraction gap closure time
They won't close faster than about 1mm per month, and sometimes not even that fast. Best of luck to you!
Mine took almost 2 years to close. My left canine took a long time to move toward the molar, once it did, it didn't take too long close the rest of the gaps.
I had 4 teeth removed. The gaps closed pretty quickly. My ortho had me wear rubber bands 24 hours a day to help close the gaps. It was less painful than I expected it to be though. Good luck!
Mine also took 24 months (I had 4 premolars removed because of bimax protrusion) despite of the rubber bands and the power chains. I agree that the lower ones are the most difficult to fully close.Teslathecat wrote: ↑Mon Mar 11, 2019 12:25 pmMine took almost 2 years to close. My left canine took a long time to move toward the molar, once it did, it didn't take too long close the rest of the gaps.
