Frequency of lig changes
Jami1
#1 Post by Jami1 » Thu Dec 27, 2018 9:29 pm
Does anyone know how the frequency of ligature changes effects progress? My ortho office has said I can come in whenever I feel the need to have ligs changed due to staining. I have read that it takes about 3 weeks for the remodeling process to occur after ligature change.
Does changing every two weeks deter that process.? It would seem that more frequent changes would keep the forces tighter on the wire and in effect make movement faster but I am unsure. With the self lighting brackets, isn’t the force constant ? If so, it would make sense that more frequent ligature changes would actually enhance movement as the ligatures wouldn’t have as much time to get stretched out.
Momto5boys
Re: Frequency of lig changes
#2 Post by Momto5boys » Thu Dec 27, 2018 10:58 pm
My ortho has me come in every 4wks.
assertives
#3 Post by assertives » Fri Dec 28, 2018 3:44 am
I have gone back to my ortho to get my powerchain changed once when a part of it broke 1 week since my last appointment, once when I was 2 weeks in and also a couple of times when I was 5 weeks in when I was not able to get an appointment. My appointments are usually 4 weeks apart. My uneducated guess is while there are some effects to frequent changing of ligatures, they don't make that much difference to the overall treatment.
EllieMilo
#4 Post by EllieMilo » Wed Mar 13, 2019 9:56 am
My adjustments are also 4 weeks apart.
Lovespain5
#5 Post by Lovespain5 » Thu Mar 14, 2019 5:38 pm
Mine had been changed at each appointment so every 4 weeks too.
:?:-#):mrgreen:
Nozzelnut
#6 Post by Nozzelnut » Fri Mar 15, 2019 3:05 pm
As little as 2 but usually 4 weeks.
Upper ceramics 5/21/14, Lower stainless 5/28/14
Double jaw surgery was 6/18/15. Estimated time Jan 2016; still on at my 2 year anniversary...
Braces removed 7/20/18; upper and lower Hawley and Essix retainers with bonded lower too.
I'm emphatically against extraction orthodontics! It's easier for the orthodontist; not better for the patient!!!
Gia
#7 Post by Gia » Fri Mar 15, 2019 6:52 pm
My appointments have been every 6 weeks for routine adjustments. I have had some ligatures changed in between when brackets needed to be rest. My understanding from my orthodontist is that it's the wire that does the work and the ligatures just keep it in place. I'm guessing changing them more frequently won't make much difference. Also I think the issue of orthodontic force is important, and 2 much can lead to more complications such as root resorption. Faster isn't always better.
Speck
#8 Post by Speck » Sat Mar 16, 2019 8:51 am
I suspect that each time the arch-wire is replaced, new ligs go in.
-Andy
Mndstevens
#9 Post by Mndstevens » Tue Apr 09, 2019 4:11 pm
I go every 6 weeks.
