K Hook bent braces
Fiatbraces
K Hook bent braces
#1 Post by Fiatbraces »
Hello,
Just had a K hook fitted to my brace for elastics to be used, I just put my elastic on and noticed the K hook has bent a little bit, is this normal or do I need to contact my orphodontist, thanks!
Fiatbraces
Re: K Hook bent braces
#2 Post by Fiatbraces »
I would really appreciate any help, I live 2 hours away from my orphodontist so don’t want to have to travel there
assertives
#3 Post by assertives »
Give your ortho's office a call. He/she will be able to tell you if they need you to come in to get it fixed or if it can wait till your next appointment.
Fiatbraces
#4 Post by Fiatbraces »
Hi,
Thanks for your reply, contacted the orphodontist and said the hook will bend forward and just to push them back with a pencil eraser
assertives wrote:
Tue Nov 06, 2018 1:36 am
SDFD TSchott
#5 Post by SDFD TSchott »
Fiatbraces wrote:
Tue Nov 06, 2018 3:22 am
Hi,
Do you mean orthodontist and not orphodontist?
Adjustment Sept 14th, 2018
Braces off April 02, 2008
