Hi,
A part of my power chain unhooked from one of my brackets, I used like a small metal spike and rehooked the power chain to the bracket, it looks fine now, is it ok I rehooked the power chain myself?
Powerchain come off bracket
Re: Powerchain come off bracket
Yeah definitely. If you can do it there's no point waiting to go to your orthodontist. I told mine that my spacers had come out and I'd put them back in and they were impressed
[quote=strinder post_id=501565 time=1523789889 user_id=29916]
Yeah definitely. If you can do it there's no point waiting to go to your orthodontist. I told mine that my spacers had come out and I'd put them back in and they were impressed :)
[/quote]
Thanks so much strinder, really appreciate your reply, it’s put my mind to rest. Thanks again
[/quote]
