Hello everyone,
Some people reopen extraction spaces and place implants. But very often its not possible to create enough space for an implant; why not just widen the arch, bring all teeth forward as much as possible( or as much as you want), and move the back molars forward?
Or, reopen the extraction space, and instead of placing implant ( expensive, risky, etc) just moving the back molars forward into the gap by using TADs for example.
I think this technique could restore Smile, lip&cheek support, and just overall aesthetics.
In my case, i "dream" of just moving everything forward almost as it used to be before the extractions, moving molars forward and then, having enough space in the back to fully align wisdom teeth.( 2 are out already, 2 halfway out, all of them to far in the back to function properly) Almost, as if the extraction never happened. But i of course i am aware it will never look like before, but i'm just tryna make the best out of it.
Any doubts ?
Please let me know your thoughts!
Reverse extraction results by expanding arch/ without implants/ with TADs
Re: Reverse extraction results by expanding arch/ without implants/ with TADs
Hi there. I'm beginning extraction reversals next week. According to my Orthodontist, we're going to expand the arches and move the teeth forward until I'm happy with the aesthetic result and then close the gaps by bringing my molars forward. However, my Orthodontist has suggested that it would work better to have implants put in if we manage to open up the spaces successfully as closing the gaps by bringing the molars forward would take a very long time. So yeah I guess implants save about 8-10 months off treatment time?
I'm curious to see how it went for you. Do you have any pictures to share on your progress?Bebamel2 wrote:Hello everyone,
Any doubts ?
[quote="Infernalxt"]Hi there. I'm beginning extraction reversals next week. According to my Orthodontist, we're going to expand the arches and move the teeth forward until I'm happy with the aesthetic result and then close the gaps by bringing my molars forward. However, my Orthodontist has suggested that it would work better to have implants put in if we manage to open up the spaces successfully as closing the gaps by bringing the molars forward would take a very long time. So yeah I guess implants save about 8-10 months off treatment time?[/quote]
Im taking a slightly different approach- We're not opening up the spaces but we will move all teeth forward at once so the space will be created Behind the molars because i am not intending to get implants anymore.
I think what your orthodontist is doing sounds good- in case it wont be possible to open up the spaces, you can just move the molars in.
Technically, implants might safe you time. But maybe you will be happy with the aesthetic result even though the spaces are not 7mm open yet, and that would safe you time too. And it would be less damaging for your teeth to not expand this much ;)
I would Really like to know what appliance you will be using ! How are you going to expand?
[quote="Bebamel2"][quote="Infernalxt"]Hi there. I'm beginning extraction reversals next week. According to my Orthodontist, we're going to expand the arches and move the teeth forward until I'm happy with the aesthetic result and then close the gaps by bringing my molars forward. However, my Orthodontist has suggested that it would work better to have implants put in if we manage to open up the spaces successfully as closing the gaps by bringing the molars forward would take a very long time. So yeah I guess implants save about 8-10 months off treatment time?[/quote]
I would Really like to know what appliance you will be using ! How are you going to expand?[/quote]
Hi :)
So I just got my appliance 2 days ago. Since I only took off my braces three months ago (where they did extractions), I haven't really experienced bone remodelling nor do I need to expand my maxilla so we are just using springs coils. I have on the Damon Clear system. According to my orthodontist, the Damon's are good enough to expand the arches and the coil springs will be fine to open up the spaces.
At the moment I just have on a light wire with the springs. This month we just want to straighten things up and then we will put in a high torque wire to pull teeth forward and out (they're tipped onwards). That in itself will create a lot of space. After that we will start expanding.
When I put on my braces I already had a mm open at all 4 points from not wearing my retainer. I think that's a sign that my teeth naturally want to move forward and not stay in that awful retracted position.
Do tell me the details of your treatment? I'd like to hear about others going through what I have. :)
Hi :)
Hello,
Thanks for the information! Its really helpful to know what kind of treatments other people are going through.
Right now i cant tell you much about my treatment, because we've just began talking about it.
I'll keep you updated on the details.
We will defnitely spend lots of time on planning it carefully, he'll make models of what the results will look like etc etc so there wont be any disappointments.
I hope everything goes well with your treatment.
[quote="Bebamel2"]Hello,
I hope everything goes well with your treatment.[/quote]
Hi Bebamel,
Any updates on your course of treatment?
Hi Bebamel,
[quote=Bebamel2 post_id=498565 time=1510614444 user_id=30878]
Hello,
[/quote]
Hi Bebamel
Please update on treatment!
Hello,
[/quote]
Hi Bebamel
