Want to buy waterpik!
bi167
#1 Post by bi167 »
Hi all,
I want to order waterpik but I don't think in India it's available easily. From where did you order it and how much it costs? which are trusted manufacturers and and of which company or brand did you buy?
From what i know it's very use full.
Impacted upper right canine,
Severe crowding in lower jaw,
Had lower 2 premolars extracted on 10 June 2017,
Sentenced for 1.5 to 2 years.
WanderingWallflower
Re: Want to buy waterpik!
#2 Post by WanderingWallflower »
bi167 wrote:Hi all,
Check amazon india, I just checked and they have the same certified ones that are available in the United States.
jk40
#3 Post by jk40 »
I have just ordered one for myself. In the UK though so its pretty straight forward. Just went for the Waterpik brand with the ortho nozzels
bi167
#4 Post by bi167 »
Yes, found on amazon, but don't know which manufacturers are genuine. It's under no return policy. so don't know, but from reviews i think I'll order one soon.
pcspinheiro
#5 Post by pcspinheiro »
I bought one of those that you connect directly to the tap; very little risk of developing any serious fault AND was rather cheap, although it was on German Amazon, not sure if they will send to India but there are many sellers on other platforms selling this kind of stuff. Not advertising or anything, but I got this:
https://www.amazon.de/gp/product/B01CZD ... UTF8&psc=1
bi167
#6 Post by bi167 »
Thanks. Will sure try and search this one too.
