How long is your estimated treatment time?
Tyrantblade
#1 Post by Tyrantblade » Thu Dec 01, 2016 4:09 pm
Just wondering where along the line we all fit.
I suspect most of us are probably estimated at 18-24 months, which seems to be a fair estimated treatment time, unless your case is mild (either due to luck or because you are getting treatment a second time); I'm estimated at 24 months, and I'm approaching month 16, so almost 2/3rds down.
It seems like the time has been flying by, but then again, it's has been over a decade of delaying (because as a teenager parents didn't have the money, not because I refused lol).
Lots of crimes here
3. Open bite
Braces removed since 11/06/17
shortcircuit
Re: How long is your estimated treatment time?
#2 Post by shortcircuit » Thu Dec 01, 2016 5:35 pm
18 months + surgery + 12 months, I have a significant discrepancy between what I have and what I need so I wouldn't be surprised to see even more time tacked onto that :(
Tyrantblade
#3 Post by Tyrantblade » Thu Dec 01, 2016 6:30 pm
shortcircuit wrote:18 months + surgery + 12 months, I have a significant discrepancy between what I have and what I need so I wouldn't be surprised to see even more time tacked onto that :(
I'm glad I didn't need surgery or extractions, especially surgery, time isn't quite a bother (usually anyways), I can only imagine how the recovery from surgery is, plus the cost
Lots of crimes here
3. Open bite
ladyt
#4 Post by ladyt » Fri Dec 02, 2016 9:05 am
My estimated treatment time is 30 months.
Swiper
#5 Post by Swiper » Fri Dec 02, 2016 5:50 pm
6-9 months but that includes the Wilkodontics procedure I had 2 weeks ago.
sandiego88
#6 Post by sandiego88 » Fri Dec 02, 2016 6:37 pm
18 months. I just passed the year mark. I needed surgery but decided to forego it.
arraye
#7 Post by arraye » Sat Dec 03, 2016 4:00 pm
Ive been told to expect three years, that's including surgery, from when I start in Jan 17. A bit longer than average because my teeth are a bit wonk.
FlowerPower
#8 Post by FlowerPower » Tue Dec 06, 2016 4:48 pm
30 to 35 months depending on my treatment.
cconant1833
#9 Post by cconant1833 » Wed Dec 07, 2016 7:29 am
My estimated time was 20 months. I'm sitting at nearly 40 months right now, but my permanent retainers are on and I've been told my braces will come off as a "New Years" present. I have an appointment Friday and will probably make me debracing appointment then.
I'm not really sure why it took so long other than my ortho is a perfectionist (which is NOT a bad thing!). I also had to have an impacted canine extracted, 3 wisdom teeth extracted, and I'm getting the first step to an implant done on Monday for a molar I had pulled as a child.
JanineJanine
#10 Post by JanineJanine » Wed Dec 07, 2016 8:38 am
Braces time is estimated 18-24 months. Pre-braces there was an additional 4 months of consultations, deciding on treatment, extractions and healing.
Shelleyt
#11 Post by Shelleyt » Wed Dec 07, 2016 7:49 pm
24 months, hopefully decreased due to use of acceledent and wilckidontics, but sadly I am actually behind schedule so far
littleb3ar
#12 Post by littleb3ar » Wed Dec 07, 2016 9:02 pm
Got my braces on 11/28/16 & four premolars taken out 12/3/16. I was told my treatment time will be about two years. Hopefully it ends up being shorter than that.
shanlola
#13 Post by shanlola » Mon Dec 12, 2016 6:30 am
Mine is 15-18 months and I am currently 10 months in, however I think my treatment will last longer than the estimated 18 months as I need two extractions next month and cannot imagine they will be closed in the space of 7 months! I
BrunetteMoment
#14 Post by BrunetteMoment » Mon Dec 12, 2016 9:35 am
18 months. It was my choice wether or not to get surgery, and I chose not to. Instead my ortho will "camouflage" my overbite. No extractions necessary.
Damon Metal. 18 months.
Fixing: Overbite, overjet, crowding.
KH88
#15 Post by KH88 » Wed Dec 14, 2016 1:48 am
I had ceramics upper and lower plus TPA fitted 29th November with an estimate treatment time of 2 years but I'm hoping I can get them removed a little sooner as I turn 30 in October 2018 and it'd be nice to have the job done by then!
