How long did you use wax for?
guilder68
#1 Post by guilder68 »
I"m wondering how long people use wax for. I started using it half way through day 2 (I'm on day 3) and now have it on every bracket haha!
How long do people end up using wax for? I can see it being a pain in the butt. I'm 48, and could have these on for up to 30 months. I have ceramic brackets on the top only at this point
SingleJawMelb
Re: How long did you use wax for?
#2 Post by SingleJawMelb »
You use it to release chafing in the moth. Your inside mouth quickly hardens up. You won't be using it for 30 months. Why have you got it on every bracket?
braceasaurus
#3 Post by braceasaurus »
I've had my braces a grand total of 10 days and had stopped using the wax by yesterday - so hang in there, it does get better! If you can handle it, it might be good to have periods of time where you don't use the wax, so that your mouth can build up a tolerance (i.e. hard skin) to it.
Interesting that you're experiencing irritation with the ceramic, I've got ceramic on my top six and steel everywhere else and it was only the steel that was giving me grief. I guess it depends on where they're positioned and how the wires are sitting etc.
Braced on 27.10.16 to fix an anterior open bite, overjet & mild crowding. Class 1 malocclusion. Ceramic braces upper 6 + steel lower, then double jaw surgery in about a year, once my extraction gaps have closed!
Sentence: 24-30 months.
littlething
#4 Post by littlething »
My first 2 week in braces, I went through almost a case of wax a day. I've probably used 1 case since those first two weeks (I'm 7 months in).
whitney555
#5 Post by whitney555 »
I used it for the first two months, mainly where the posts on my brackets would carve out little ruts into the inside of my lip. Those took forever to heal, and eventually even the wax didn't help any more because the cuts got too big. I got so frustrated at the wax that I just started shoving pieces of cotton ball between my brackets and the inside of my cheek. That actually worked surprisingly well, and it's now my go-to move if I get a sore spot.
SingleJawMelb
#6 Post by SingleJawMelb »
whitney555 wrote:I used it for the first two months, mainly where the posts on my brackets would carve out little ruts into the inside of my lip. Those took forever to heal, and eventually even the wax didn't help any more because the cuts got too big. I got so frustrated at the wax that I just started shoving pieces of cotton ball between my brackets and the inside of my cheek. That actually worked surprisingly well, and it's now my go-to move if I get a sore spot.
Blue TAC is also great
bez
#7 Post by bez »
I used it a few times I think in the first week. In my experience, the irritation usually only lasts a day or two and putting wax on only delays it so I stopped using it completely.
r1r1r12000
#8 Post by r1r1r12000 »
I started using wax on day 2 and used it until the end of the first week. I haven't needed it since (about 6 weeks and one adjustment so far). Others have told me we may need to place some wax occasionally after an adjustment.
Len
#9 Post by Len »
Me and my wax didn't get along well... It turned out pointless as it would fall off easilly and I was still in pain. I healed much faster after I decided to not put wax on. Did it hurt? A lot. But it was worth it.
Gerbera
#10 Post by Gerbera »
i still use it. Bottom brackets rub from time to time.
DivineMsM
#11 Post by DivineMsM »
The first week I used it everyday, and welcomed the relief it provided. Going into week three and I've only had to use it for 2 days.
dewzer
#12 Post by dewzer »
I used it on a few brackets during the first week and that was it.
Swiper
#13 Post by Swiper »
Got my braces on Monday afternoon so i am on full day 2 and have only used wax at night to sleep. So far so good.
cocomacd
#14 Post by cocomacd »
I'm on my fifth day and up until last night I haven't had to use it. However, I think the very back bracket where the wire goes through, it might be too long because it's just irritating the heck out of me. So I put a teeny dab on the end and that felt instantly amazing! Lol
Journey Begins December 6, 2016
First time, Self ligating brackets
Age 38
Sentence: 12-18 months
braces25
#15 Post by braces25 »
I'm 11 months in and still use it from time to time when I have a random wire poking out or the brackets move and rub the inside of my cheek
